timallen's avatar
timallen
Domain controller restart requires domain rejoin on NAS Pro
On a morning after our DC (MS SBS 2008) reboots due to automatic updates, we arrive at work to find that no-one can access any shares on the NAS. We need to rejoin the domain (this morning we had to enter the wrong password, have it be unsuccessful, then enter the correct domain controller password). We then have to restore the share permissions from a config backup. After that, we are OK until next time our DC reboots.
This is a critical issue to us and is bringing into question our use of the NAS, which we only purchased within the last month or so, the issue has already happened twice, and results in significant productivity loss.
Assistance please?
Thanks, Tim Allen
Details of our NAS:
Model: ReadyNAS Pro Business Edition [X-RAID2]
Firmware: RAIDiator 4.2.15
Memory: 1024 MB [4-5-5-15 DDR2]
IPv4 address: 1: 172.16.1.12
IPv4 address: 2: Not Connected
Volume C: Online, X-RAID2, 2 disks, 70% of 1754 GB used
  • Because with our current firmware, the NTP server only syncs every 4 hours, if it were to happen to do that while the domain controller is unavailable(unlikely, but possible), it would sync to the next one on the list, and if the domain controller isn't synced the same as the NTP server that the ReadyNAS is synced to and you have a time skew issue, you end up with problems.
    The other thing to try would be to install the latest beta.
  • We reliably can reproduce the problem whenever the DC reboots, so the four hours things seems unlikely.
    I'm not really keen on running beta in a production environment.
    We really need to get this sorted as we're going to pull the pin and move to something else if the NAS can't sustain a domain connection.
    Do you have any other ideas?
    Tim
  • Well the beta does include a number of updates, and you'd be bringing a non-working system to a working state with the risk of leaving a non-working system(based on your description) in it's current state, so that's up to you.
  • keep in mind though, if you got to 4.2.16 beta you can not go back to any earlier version, due to GPT partition changes
  • Hi Grievous,
    Had a look at the list of changes for the latest beta and none of them relate to my issue.
    Where do you think I should go from here? Is there any way to get some better support from Netgear - should I raise a support ticket?
    I must say I'm really disappointed that such critical functionality is flakey.
    Are there people out there who have got domain security (using domain groups for access control) working reliably? Anyone who has Small Business Server as the DC working reliably?
    Thanks,
    Tim
  • Well if you don't want to troubleshoot(and I did give an option besides the beta) we can't help you. Off the top of my head one other thing to try would be to make sure none of your backup jobs are running during the DC reboot. The next step beyond that would likely involve giving us remote access to the ReadyNAS so we can see exactly what's going on.
  • We had problems with AD permissions on NAS probably due to a similar NTP issue when I used by ReadyNas pro with 6.67 TB of data. It would take for ever to apply permisssions once the NAS connected to the domain. In the mean time users had problems with saving files. After a month, I gave up and bought a Dell NX 3000 NAS box with windows 2008 storage server and it is working great! I use the Netgear for backing up the production Dell NAS now!
ProSupport for Business
