PipingRockIT
Jul 31, 2018Aspirant
Domain joined NAS home directories wrong permissions
We have a few of these ReadyNAS's, all domain joined for users. We recently started using the built in home folder function, but are finding some users are unable to access their folder. I found that...
Marc_V
Aug 02, 2018NETGEAR Employee Retired
Hi PipingRockIT
The NAS might have joined several Domains before and the permissions were not reset upon changing domain. The NAS is stll using the old permissions causing users not able to access their own folder.
The permissions need to be reset through backend/SSH. If you are comfortable doing that it might work. However, contacting NETGEAR Support would be advised for you to ber assisted on this step.
Hope this helps!
Regards
