dtperko
Jun 20, 2017Aspirant
Downgrade from 4.2.31 to 4.2.30?
I recently resurrected one of my ReadyNAS 4 units. The web interface is spotty as all get out - web service seems to hang after a few hours, cannot change IP address via the UI, etc. I checked an...
dtperko
Actually, right now, I cannot even get into the web admin at all:
There is something definitely broke with the web server. I was actually hoping to install the SSH module so maybe I could telnet in to review logs, etc. but I see no way to do that now either.
Thoughts on how to fix this?
-Dave
Marty_M
Jun 20, 2017NETGEAR Employee Retired
Hello Dave,
You can set the NAS on telnet(tech support mode) through the boot menu to access it via telnet locally. Please click here for guide on how to access the boot menu of the NAS just make sure to select the exact model number of your NAS since each NAS has different way to access the boot menu.
Since you have just resurrected the NAS, I assume there is no data on it. You may start with an OS re-install to reflash the OS or start with a factory reset.
Welcome to the community!
Marty_M
NETGEAR Community Team
- dtperkoJun 20, 2017Aspirant
Yup! I didn't realize "tech support mode" was also telnet mode. I am in - now I just need some advice as to what to look at to see my Frontview is failing.
I am fairly UNIX literate, so if you can direct me to the proper location for logs, etc. I can check things out. So far I've mounted the partition and have looked around at folders like the var/logs/frontview but have not seen anything obviously wrong (like huge log files, etc.)
-Dave
- StephenBJun 21, 2017Guru - Experienced User
There is the "brute force" approach where you just do a factory reset and rebuild the NAS from scratch. Similar to re-imaging a PC. Easy to do, but takes a day or so to resync, and then you need to reconfigure and reload the data. If you have no data on the NAS you need to extract, and it is being "resurrected", then I recommend that approach.
BTW, it might be possible to install OS-6 on the NAS. What model is it?
The OS reinstall won't help if it's due to a full OS partition - but if the cause is a mildly damaged OS, it might.
Since you have shell access, start by seeing if the OS partition is full before looking for log files to truncate (df . -h). Look at free inodes also (df . -i)
- dtperkoJun 21, 2017Aspirant
Its a ReadyNAS 4.
There is data on the volume which I'd prefer not to lose if possible.
At the moment, I can now Telnet/SSH into the box but it is stil flaky.
For instance, I cannot copy files TO the unit without it losing itself on the network.
I also cannot download the logs (now that I can get into Frontview) - it just sits spinning.
I hate to do a factory reset if I can avoid it...thoughts?
