gosain
Aug 11, 2013Aspirant
Drive Compatibility & Expansion Related Issues
I am planning to buy ReadyNAS RN104 Diskless because I already have 2x1TB hard drives. Specification for drives is: "Samsung Barracuda Green HD105SI 1 Terabyte (1TB) SATA/300 5400RPM 32MB Hard Drive"...
Aug 20, 2013Guru - Experienced User
I think "registering" the device with ReadyCloud is different from registering it on support.netgear.com.
Did you configure ReadyCloud on the cloud tab of the Web UI? If so, I suggest contacting support.
