gosain
Aug 11, 2013Aspirant
Drive Compatibility & Expansion Related Issues
I am planning to buy ReadyNAS RN104 Diskless because I already have 2x1TB hard drives. Specification for drives is: "Samsung Barracuda Green HD105SI 1 Terabyte (1TB) SATA/300 5400RPM 32MB Hard Drive"...
sectoid
Sep 17, 2014Aspirant
Hello,
I just bought a ReadyNAS 104 and am experiencing the exact same issue as your last post. I also went through the other problems you mentioned before, until I got stuck at the last one and found this topic. Have you found a solution yet? Thanks!
edit: to answer StephenB`s question, readycloud is disabled in the web UI. When we try to enable it, we get the error message "Cannot join to ReadyCloud" (the OP posted an image of it).
