gosain
Aug 11, 2013Aspirant
Drive Compatibility & Expansion Related Issues
I am planning to buy ReadyNAS RN104 Diskless because I already have 2x1TB hard drives. Specification for drives is: "Samsung Barracuda Green HD105SI 1 Terabyte (1TB) SATA/300 5400RPM 32MB Hard Drive"...
mdgm-ntgr
Sep 19, 2014NETGEAR Employee Retired
Your logs suggest that it is detecting an invalid user.
Generally starting new threads is cleaner and leads to less confusion (including a link to the similar thread if necessary). I can split your posts off into a new thread if you like.
I think there may have been some issues as we have been rolling out some upgrades to our servers.
Since this is a new setup and you haven't loaded data on yet perhaps if it's still not working on Monday you could try a factory reset (wipes all data, settings, everything) to get a clean setup on 6.1.9 (seeing that you have already upgraded to that) and then attempt to join ReadyCloud again?
