gosain
Aug 11, 2013Aspirant
Drive Compatibility & Expansion Related Issues
I am planning to buy ReadyNAS RN104 Diskless because I already have 2x1TB hard drives. Specification for drives is:
"Samsung Barracuda Green HD105SI 1 Terabyte (1TB) SATA/300 5400RPM 32MB Hard Drive"
I have following questions to decide about buying RN104:
1) What is the compatibility of above mentioned hard drive?
2) If above hdd is compatible with RN104, then I would like to know any performance related issue.
3) What is the logic / process of expanding the storage space for ReadyNAS RN104?
4) What will happen if at later date I decide to put two 2TB Hard Drives?
5) What will happen if at later date I decide to put only one 2TB Hard Drive?
Any help material or guidance specific to RN104 will be much appreciated.
Thanks.
Thanks.
- mdgm-ntgrNETGEAR Employee RetiredYou could try that if you prefer, but I don't think that would make any difference.
- sectoidAspirantThe factory reset also didn't work. I think the problem is related to that "Services Offline" message on the cloud tab. It shows that the NAS's got internet access but it doesnt seem to be talking to the servers. Right after the initial configuration it says "Connecting...", then changes to "Services Offline" and keeps at that. If I refresh the page, it goes to "Connecting..." again and then "Services Offline". I can't understand how a brand new product can have this kind of problem, if it connects to the internet, it's either a software bug or a misconfiguration. But if it was a misconfiguration, it would happen to all.
My router is a Netgear R7000, also brand new, all default configuration. - sectoidAspirantThe support case was escalated to level 3 and they asked me remote access to my machine and ssh access to the NAS. I'm not pleased with the remote access to my machine but I provided it because I can't waste any more time on this.
- sectoidAspirantI've finally been able to pinpoint the problem myself, it was the new netgear nighthawk router. I've exchanged it for an old TP-Link router with DD-WRT firmware and all worked well.
The problem persists for me because I bought the Nighthawk to use it. I now know that it's having problems with other things like Netflix, all with default configurations. I tried updating the firmware, opening ports, setting DMZ mode and NAT filtering to open. Nothing fixes Netflix. However, after registering the ReadyNAS on ReadyCLOUD with the TP-Link router, I've never gotten the "Services Offline" message again, even when using the Nighthawk. Alas, the ReadyCLOUD interface cannot access the ReadyNAS when using Nighthawk.
Well at least I've found the culprit.
EDIT: forgot to say, support has not been much help. Level 2 was better than level 3, at least he replied me within a reasonable time.
