TomBlack
Sep 28, 2017Guide
Drive Info Truncated on Admin Screen
Firmware 6.8.1 Drive Info on the Admin Screen System/Performance/Internal is truncated on the left side. Seems there is plenty of room to expand this field to show all drive info.
evan2
Sep 28, 2017NETGEAR Expert
We need to conside all models,
for some models, they have more FAN and PSU,
there is not plenty of room to expand this field to show all drive info,
Anyway, I will report it again.
Thanks.
- StephenBSep 29, 2017Guru - Experienced User
Netgear could of course put the status information (size and temp) in a line below the drive, which would free up the needed space. Or only report temp in C or F, not both (user configurable).
Note if you hover over the green ball icon next to the drive, you will see the full information (and the serial number).
- TomBlackSep 29, 2017Guide
Seems to me there is space to expand that one field to the right by 10 characters or so and not truncate or lose any info.
- SandsharkSep 29, 2017Sensei
If you got rid of the silly animated fan and thermometer pictures, there would be plenty of room.
