cwiebe
Nov 10, 2014Aspirant
Drive Lost after 5.3.11 update
ReadyNas Duo+. I updated the firmware to the latest 5.3.11 and on reboot of the NAS one of the drives(volumes) is not recognized and the blue light is flashing. I was able to reboot the NAS and do a v...
mdgm-ntgr
Nov 12, 2014NETGEAR Employee Retired
Well something happened. Without looking at your logs it is quite difficult to speculate.
So long as you maintain good backups the filesystem shouldn't be an issue. Most NAS units run on Linux. Filesystems such as EXT4 and more recently BTRFS on our ReadyNAS OS devices are used.
It sounds like for the internal drive at least you might have encountered a rare software issue, though equally if the logs show SMART errors then that would suggest a problem with the disk.
Even if you won't use the NAS for primary storage you could use it for backups. If your data is important to you don't store it on just the one device. Also make sure you make regular backups with one copy stored off-site at all times.
