Chobe
Feb 01, 2016Aspirant
Drive replacement for Readynas RN10400
Where in the netgear provided handbooks does it provide instructions for 2 of 4 failing drives. For example, does new replacement drive need to be formatted. Can 2 drives be replaced at same time. ...
Chobe
Feb 16, 2016Aspirant
Thank you for your reply. I unfortuneately had some employment issues to deal with so was unable to address until now. Because I have a data file exceeding 6TB's I really didn't have a backup option unless I purchased a business license with dropbox/chrome to exceed the size of the typical free offering. I see now that was poor planning and a dumb move on my part. Is there a way to estimate the size of a backup file - thinking the file would be compressed, or can I just assume it will be the same size as the orginal file?
Feb 16, 2016Guru - Experienced User
If the folder had the compression option set, then it would be compressed. Otherwise not. There's no way to see the compressed size.
