csmmsc
Jan 18, 2014Aspirant
Dropbox on OS6
Hello, Is it possible to get Dropbox running on OS6? I have a 314, and I know you can backup to dropbox, but I need full sync as we could in he older models. I've tried everything I can to get i...
csmmsc
Jan 20, 2014Aspirant
Thanks ClaesBas,
Doesn't seem to be the problem - I tried mucking round with it but still can't get it running.
See some of the stuff I've tried below. It keeps telling me "The Dropbox daemon is not installed! Run "dropbox start -i" to install the daemon" but running "dropbox start -i" doesn't start it.
root@HOME:~# mkdir -p ~/bin
root@HOME:~# wget -O ~/bin/dropbox.py "https://www.dropbox.com/download?dl=packages/dropbox.py"
--2014-01-20 18:25:04-- https://www.dropbox.com/download?dl=packages/dropbox.py
Resolving www.dropbox.com (www.dropbox.com)... 108.160.166.20
Connecting to www.dropbox.com (www.dropbox.com)|108.160.166.20|:443... connected.
HTTP request sent, awaiting response... 301 MOVED PERMANENTLY
Location: https://linux.dropbox.com/packages/dropbox.py [following]
--2014-01-20 18:25:06-- https://linux.dropbox.com/packages/dropbox.py
Resolving linux.dropbox.com (linux.dropbox.com)... 108.160.166.13
Connecting to linux.dropbox.com (linux.dropbox.com)|108.160.166.13|:443... connected.
HTTP request sent, awaiting response... 200 OK
Length: 111424 (109K) [application/octet-stream]
Saving to: `/root/bin/dropbox.py'
100%[=====================================>] 111,424 200K/s in 0.5s
2014-01-20 18:25:09 (200 KB/s) - `/root/bin/dropbox.py' saved [111424/111424]
root@HOME:~# ~/bin/dropbox.py help
-bash: /root/bin/dropbox.py: Permission denied
root@HOME:~# chmod +x ~/bin/dropbox.py
Dropbox command-line interface
commands:
Note: use dropbox help <command> to view usage for a specific command.
status get current status of the dropboxd
help provide help
puburl get public url of a file in your dropbox
stop stop dropboxd
running return whether dropbox is running
start start dropboxd
filestatus get current sync status of one or more files
ls list directory contents with current sync status
autostart automatically start dropbox at login
exclude ignores/excludes a directory from syncing
lansync enables or disables LAN sync
root@HOME:~# ~/bin/dropbox.py start
Starting Dropbox...
root@HOME:~# dropbox start -i
Starting Dropbox...
Dropbox is the easiest way to share and store your files online. Want to learn more? Head to https://www.dropbox.com/
In order to use Dropbox, you must download the proprietary daemon.
Note: python-gpgme is not installed, we will not be able to verify binary signatures. [y/n] y
Downloading Dropbox... 100%
Unpacking Dropbox... 100%
Starting Dropbox...
root@HOME:~# ~/bin/dropbox.py start -i
Starting Dropbox...^CTraceback (most recent call last):
File "/root/bin/dropbox.py", line 1387, in <module>
ret = main(sys.argv)
File "/root/bin/dropbox.py", line 1376, in main
result = commands[argv[i]](argv[i+1:])
File "/root/bin/dropbox.py", line 1247, in start
if not start_dropbox():
File "/root/bin/dropbox.py", line 740, in start_dropbox
time.sleep(interval)
KeyboardInterrupt
Starting Dropbox...
root@HOME:~# apt-get install -y python-gpgme
Reading package lists... Done
Building dependency tree
Reading state information... Done
The following extra packages will be installed:
libgpgme11 libpth20
Suggested packages:
gpgsm gnupg2
The following NEW packages will be installed:
libgpgme11 libpth20 python-gpgme
0 upgraded, 3 newly installed, 0 to remove and 30 not upgraded.
Need to get 515 kB of archives.
After this operation, 1,393 kB of additional disk space will be used.
Get:1 http://mirrors.kernel.org/debian/ wheezy/main libpth20 amd64 2.0.7-16 [83.3 kB]
Get:2 http://mirrors.kernel.org/debian/ wheezy/main libgpgme11 amd64 1.2.0-1.4 [349 kB]
Get:3 http://mirrors.kernel.org/debian/ wheezy/main python-gpgme amd64 0.2-3 [83.2 kB]
Fetched 515 kB in 9s (55.9 kB/s)
debconf: delaying package configuration, since apt-utils is not installed
Selecting previously unselected package libpth20.
(Reading database ... 16972 files and directories currently installed.)
Unpacking libpth20 (from .../libpth20_2.0.7-16_amd64.deb) ...
Selecting previously unselected package libgpgme11.
Unpacking libgpgme11 (from .../libgpgme11_1.2.0-1.4_amd64.deb) ...
Selecting previously unselected package python-gpgme.
Unpacking python-gpgme (from .../python-gpgme_0.2-3_amd64.deb) ...
Setting up libpth20 (2.0.7-16) ...
ldconfig: /opt/ctch/lib64/libaivse000.so.5 is not a symbolic link
Setting up libgpgme11 (1.2.0-1.4) ...
Setting up python-gpgme (0.2-3) ...
Starting Dropbox...
In order to use Dropbox, you must download the proprietary daemon. [y/n] y
Starting Dropbox...
