duckson
Dec 02, 2011Guide
Duo - dead, no lights or fans
Hi everyone. Hope you can help. I left my Duo while i was copying a Bluray rip to it over my network and came back to find it switched off. Trying to now power on the Duo and nothing happens. Pre...
PapaBear1
Dec 03, 2011Apprentice
If it is the brick, let Netgear send you a replacement. I would absolutely not go with a third party in this situation. The plug might not fit for one thing, and the wattage may not be correct (check the stats on the bottom of yours).
