muzicman61
Apr 14, 2018Tutor
DUO and Lost+Found files
I have about 30gb of files in my Lost+Found folder (as seen from my Windows PC). I delete them and they just come back. How can I get rid of them permanently? I have no idea what they are and would l...
Apr 16, 2018Guru - Experienced User
muzicman61 wrote:
I tried to delete them via ssh but when I go into that directory I don't see the file even using the ls -la command. Thanks!
You should be able to go into the lost+found folder. Where are you looking?
Generally speaking, when linux uncovers file system issues, it will often put files (or parts of files) into lost+found. This can happen when the system does a volume scan (which if often does when the NAS boots).
A brute-force approach is to back up the NAS, do a factory default, reconfigure it, and then restore the data from backup. But you might want to check the disk health before you do that.
- muzicman61Apr 16, 2018Tutor
Hey Stephen.... long time no see.
The health of the disks are fine. So I am seeing these files when i browse the root of the nas in Windows (\\ipaddress\c\lost+found). There is a lost+found directory and if i delete the files they go away, but then once i refresh the directory they come right back.
I used Putty to ssh directly into the DUO. From the root I saw the lost+found folder. I cd'd into that folder but don't see any files.
I could back everything up to another nas and do the restore but that seems like a drastic solution.
- StephenBApr 17, 2018Guru - Experienced User
Do you mean the OS partition, or did you also look on /c for the lost+found folder?
Definitely been a while :smileyhappy: Nice to hear from you.
