PeterD2
Jun 14, 2014Aspirant
DUO: Any way to get a 4TB drive to recognize?
Hi all, I have an older ReadyNAS DUO with 4.1.13 firmware, currently running a pair of 2TB Seagate drives, which are full-to-bursting, and I'm currently being forced to delete old stuff off of it (on...
PeterD2
dishmagic66 wrote: If i am right the Duo supports only up to 2TB capacity drives. For using larger capacitys drives you need newer models like the 102 and 104.
If i am wrong one of the Readynas Guru's will correct me.
Ugh. I just ordered a 102 diskless and hopefully that will work.
Another question: Will my old DUO support backing up a Mac using Time Machine?
