etxbilr
Nov 20, 2014Aspirant
DUO expansion problem
Hi, i've got an DUO in X-RAID that I've performance expansions on a few times. Started with 500 GB driver, upgraded to 1 TB then 2 TB. As these are getting close to 90% I bought 2 WD 30EFRX after checking that then we're included in the approved harddisc list.
I've now tried hotswapping them, and both are indicated as Dead after installation. Also tried to restart the duo to see if this helped.
My next step would be to switch off the DUO and try a factory reset with only one of the new discs inserted, making sure it's being formatted the correct way. But IF this is successful, can I then install one of the old discs containing all the data, and sync with the new disc, or will the old disc be wiped clean as the new disc is empty?
I'm running the latest firmare but haven't done any factory reset since prior to expanding IT with the 2 TB discs (to included the 4k sector?)
Hope you can advise.
- StephenBGuru - Experienced UserFirst confirm your model number via this link: http://www.rnasguide.com/2012/01/09/how ... -or-nv-v2/
If it is running 5.x.x firmware, then it is compatible with the WD30EFRX.
But if the DUO is running 4.1.x firmware then it does not support 3 TB drives. Since you talk about 4K alignment, I am thinking you have a DUO v1 with 4.1.x firmware. If so, you simply can't go to 3 TB drives, you are maxed out now. So you'd need a new NAS. An RN102 is much faster than your duo, and is quite inexpensive.
So I think your next step is to switch off the NAS and install the two original drives (in their original slots if possible). Then power up, and confirm your data is still intact. Check with RAIDar right after booting up, and if it seems to be doing a factory install immediately power it down. There's about a 5 minute window to check.
Then invest in a second NAS. You can split your data across them both, or use the duo to back up critical data. I'd go the latter route, and rebuild the duo in jbod mode after the migration to the new unit. That would give you two 2 TB volumes, which should be enough to back up the new NAS. - etxbilrAspirantHi StephenB,
I'm afraid you're absolutely correct. I was under the impression that I had a V2, but as I've just updates to 4.1.14 I'm proven wrong :oops:
As to the proposal to install the old driver I'm ahead of you. That was my first action after trying the new drives. So next step wil be to hunt down a new Netgear NAS as I'm quite happy with the performance. And as my network is bult around Netgear equipment why change :neener:
Thanks for your speedy respons!
BR / Bjorn - StephenBGuru - Experienced UserThe RN102 is reasonable, but in general leaving some empty slots makes future expansion cheaper. So an RN104 might be more economical long term (starting it out with 2x3TB). You can expect around 70 MB/s read speed and 50 MB/s write speed - a lot faster than the duo v1. That is with antivirus turned off.
An RN314 will give still better performance (similar to the x86 ultra). Though it is more expensive of course. - etxbilrAspirantWorth considering for sure. Would it be possible to start the new NAS with the old 2 TB disc with all data and then perform an expansion with the new 3TB disc, and would the choice of new version of NAS dictate this possibility ( as they're using different CPU platforms I'd expect this )?
- mdgm-ntgrNETGEAR Employee RetiredYou could only migrate your array to another Sparc NAS. Sparc NAS units are limited to 2TB disks.
We do have a data recovery procedure but that is a last resort when the Sparc NAS e.g. has failed and won't respond at all to attempts to power it on.
Best to get a new NAS with new disks and transfer the data across your network. - etxbilrAspirantHi mdgm, and thanks for the clarification. I guessed as much but wanted to make sure. And this of course open up for going with the RN104 suggested by StephenB.
Big Thanks for the swift responses to my queries. Great forum!! :thumbsup:
