chriscowanuk
Feb 18, 2017Aspirant
Duo V1 Dead
My Duo V1 made a popping sound and went dead. Assume something has blown inside. I can probably cobble together a recovery from USB backup and offsite backup although the latter is out of date. The qu...
- Feb 19, 2017
No, connect them to your Windows PC either with a Sata cable or a USB drive caddy
Feb 18, 2017Guru - Experienced User
If you were using the default XRAID then R-Linux for Windows should be able to access the data volume from drive 1,
