chriscowanuk
Feb 18, 2017Aspirant
Duo V1 Dead
My Duo V1 made a popping sound and went dead. Assume something has blown inside. I can probably cobble together a recovery from USB backup and offsite backup although the latter is out of date. The qu...
- Feb 19, 2017
No, connect them to your Windows PC either with a Sata cable or a USB drive caddy
chriscowanuk
Feb 19, 2017Aspirant
Do I need another Duo V1 chassis to put the disks into?
- bedlam1Feb 19, 2017Prodigy
- chriscowanukFeb 19, 2017Aspirant
I find I have another problem which is I can't get the disks out of the dead Duo V1, because you need power to unlock the disk enclosures! Oh dear. Any ideas?
