sendjes
Nov 22, 2012Aspirant
Duo V1, no Gbit
Sorry for the odd topic-title, but I thought my Readysnas Duo had Gbit connection, but either i'm wrong og plain confused, here's a screenshot of what i'm talking about:
http://i.imgur.com/bZTPd.png
The Speed/Duplex is what i'm curious about, is my Nas just too old for Gbit?
- sendjesAspirantHangon, right now I can't access the damn thing.
- mdgm-ntgrNETGEAR Employee RetiredInteresting. How recently did you install the 2TB disks?
- sendjesAspirantHad to work hence the late reply, I installed them today, and I just tried to turn it of and start it again, the blue light just keeps flashing, I guess it hates me for al my complaints about it hehe.
- mdgm-ntgrNETGEAR Employee RetiredCan you see it in RAIDar (http://kb.netgear.com/app/answers/detail/a_id/20684/)?
It's possible the disks could have still been undergoing the initial resync which would explain the performance. - sendjesAspirantNo luck with RAIDar, tried it earlier, and the blue led still flashes, i'll let it flash til tomorrow morning ( in 6-7 hours ) hopefully you're right, and it's "just" doing a resync.
- sendjesAspirantWell, I took out my Red HDD inserted my Green, factory reset, and here are some screenshots:
Volumes > Volume Settings: http://i.imgur.com/Fe6eu.png
Transfer speed from Windows to Nas: http://i.imgur.com/NnV1h.png <-- Max speed was 14MB/s
Transfer speed from Nas to Windows: http://i.imgur.com/KvbwR.png <-- Max speed was 10MB/s - mdgm-ntgrNETGEAR Employee RetiredAnd that's faster than what you'd get over 100 Mbit
How many WD RED disks did you have in the NAS? - sendjesAspirant1 WD Red 2TB which I couldn't get to work.
and yes the 14MB/s is more than 100Mbit I know. - mdgm-ntgrNETGEAR Employee RetiredYou should check that disk using WD LifeGuard Diagnostics.
- sendjesAspirantI will do that after I get some sleep, thanks.
