OBx2
Dec 18, 2013Aspirant
Duo V1 Power Timer
Readynas Duo V1 - Radiator 4.1.13 When I set the power timer to power off and then on, the power off never completes - the fan runs at high-speed continually (I've left it for a little over an hour...
OBx2
Dec 19, 2013Aspirant
It's never worked.
The device does power off - all the lights go off. It just never completes the power off (running fan).
DLNA and it behaves the same with no add-ons running.
Well, I don't know how to re-install the OS, but it's had at least two firmware updates over the years.
