jools1
Aug 15, 2013Aspirant
Duo v1 will not boot - No Disk Detected
Hi, I've just been given a friends readynas duo to fix because I "know about computers" and have recently had assistance fixing a pro2, my friend would like to try and get the unit working, it has ...
jools1
Hmmm, according to the warranty check it's not been registered yet which may not necessarily be a good thing. I've emailed him but I dont expect there will be a positive outcome on the possibility of replacement hardware without a receipt of some sort.
Whats your feelings on the state of the unit? Is it bricked? Can anything be done to get it to at least try and boot?
I would have thought something would/should have appeared on the console on power up but immediately goes to the flashy lights sequence. Is there another method of getting a console? I presume 9600 8-n-1 is right? It certainly seemed to work with the pro unit. Also, I can see another pin block, looks to be about 5 or 6 pins just above the serial console, anyone know what thats for?
I can continue guessing all night so it might be time to give it a rest until tomorrow.
If anyone has any tips I can try please feel free to share.
Thanks
Jools
Thanks
Jools
