jools1
Aug 15, 2013Aspirant
Duo v1 will not boot - No Disk Detected
Hi, I've just been given a friends readynas duo to fix because I "know about computers" and have recently had assistance fixing a pro2, my friend would like to try and get the unit working, it has ...
jools1
Aug 17, 2013Aspirant
Hi, there is definitely a serial console, it's that slot on the back of the unit covered with sticky tape.
I've used it on the Pro2, a Duo v2 and an old Duo before, though it's possible I may have the wrong settings for speed/flow control. I'd usually see some crap on the screen when I get these wrong but I dont get anything.
I'll pm chirpa as suggested. it's not looking too bright at the moment, the chap says he might have shredded the old documents as he certainly cant find them.
Does the light sequence I described have any other meanings apart from "No disk detected"? perhaps like "give up it's really broken!"
Thanks for the info.
Cheers
Jools
Cheers
Jools
