fesh
Nov 06, 2012Aspirant
Duo V2 - Admin Password
Today I removed the old disk (had only one) from my Duo v2 and added two 2TB disks (WD20EARX). Entered the boot menu and chose the Factory default boot mode. 5 hours later RAIDar showed that the sync...
Nov 06, 2012Guru - Experienced User
If you have a duo v2, the default password is not "netgear1" - it is "password"
