fesh
Nov 06, 2012Aspirant
Duo V2 - Admin Password
Today I removed the old disk (had only one) from my Duo v2 and added two 2TB disks (WD20EARX). Entered the boot menu and chose the Factory default boot mode. 5 hours later RAIDar showed that the sync...
mdgm-ntgr
Nov 06, 2012NETGEAR Employee Retired
Stephen is correct.
Yes the Duo v2 automatically updates the firmware when you do a factory default.
