alboccio
Apr 14, 2014Aspirant
DUO v2 dashboard not loading in Chrome
Hi, I am not able to log into the Dashboard on my Duo v2 using Chrome Version 34.0.1847.116 m. I am able to use Firefox ver 28.0. Is there a fix for this problem? I would rather have only one br...
brinzlee
Apr 16, 2014Aspirant
I certainly hope this will be addressed...I have updated my Duo V2 to 5.3.10 so that it could interface with IE 11 but that doesn't work correctly either. If you go into the shares section, the information is all out of sync when you try and scroll the details on the right hand side....and now you can't access via chrome either.....what a sad sorry state.....How are you to maintain the NAS if you haven't got a working interface !!!
Another ReadyNas nail in the coffin !!
