alboccio
Apr 14, 2014Aspirant
DUO v2 dashboard not loading in Chrome
Hi, I am not able to log into the Dashboard on my Duo v2 using Chrome Version 34.0.1847.116 m. I am able to use Firefox ver 28.0. Is there a fix for this problem? I would rather have only one br...
Apr 16, 2014Guru - Experienced User
Netgear reports that the Chrome issue with OS6 is actually a Chrome bug, which will be fixed in version 35.
mdgm wrote: I don't know if this issue will be addressed or when a firmware update would be made available if so. Considering the product is EOL it could be a while
They haven't commented on the v2, but it sounds to me like temporarily using Chrome 35 beta might be worth a try.
