alboccio
Apr 14, 2014Aspirant
DUO v2 dashboard not loading in Chrome
Hi, I am not able to log into the Dashboard on my Duo v2 using Chrome Version 34.0.1847.116 m. I am able to use Firefox ver 28.0. Is there a fix for this problem? I would rather have only one br...
brinzlee
Apr 19, 2014Aspirant
Just a note of caution to anybody else who has upgraded there ReadyNas V2 to 5.3.10. If you were using 5.3.9 with Internet Explorer 11 as a workaround you needed compatibility settings set in the browser. Don't forget to remove this setting if you use the upgraded firmware 5.3.10 or the browser won't display some of the pages correctly.....Just worked that one out........then 5.3.10 and IE 11 work happy together
That just leaves Google Chrome to sort out there act now.....and all's happy in the world !!
:D
:D
