sphardy1
Mar 26, 2012Apprentice
Duo v2: Device is Offline
Anyone any idea what this means? Came across it when connecting to Dashboard to check on Diskspace usage, not because of any issue - as I haven't had any. Running firmware 5.3.3. BTW -...
Wish
Mar 26, 2012Aspirant
I am pretty sure you get that message when your hard disks are in the process of spinning up from being asleep. If you were to try to connect to the dashboard a 2nd time 15 seconds later you should connect.
