sphardy1
Mar 26, 2012Apprentice
Duo v2: Device is Offline
Anyone any idea what this means? Came across it when connecting to Dashboard to check on Diskspace usage, not because of any issue - as I haven't had any. Running firmware 5.3.3. BTW -...
HERBIEO
Aug 03, 2012Aspirant
Dont need to do a factory reset to reinstall firmware as that will destroy all your data, just do a OS reinstall that will reinstall the firmware
instructions here http://www.readynas.com/kb/faq/boot/how_do_i_use_the_boot_menu
