sphardy1
Mar 26, 2012Apprentice
Duo v2: Device is Offline
Anyone any idea what this means? Came across it when connecting to Dashboard to check on Diskspace usage, not because of any issue - as I haven't had any. Running firmware 5.3.3. BTW -...
mdgm-ntgr
Aug 05, 2012NETGEAR Employee Retired
The NAS uses the copy of the OS already in the flash for an OS Re-install. That RAIDiator download is installed via the web-admin interface. If the firmware update needs to be downloaded and re-applied to the flash NetGear support can assist with that.
