sphardy1
Mar 26, 2012Apprentice
Duo v2: Device is Offline
Anyone any idea what this means? Came across it when connecting to Dashboard to check on Diskspace usage, not because of any issue - as I haven't had any. Running firmware 5.3.3. BTW -...
mdgm-ntgr
Nov 07, 2012NETGEAR Employee Retired
1) Incorrect. EXT4 is a standard Linux filesystem and considered by many to be the best for Linux at this time. Easy enough to put the disk in a Linux machine, use mdadm to start the RAID, do a vgscan to discover the data volume, run vgchange -ay c, then mount /dev/c/c/ mnt to mount the data volume.
2) If you need high availability in an AD environment you shouldn't rely on a single domain controller. Also I'd argue if you need that going for the cheapest of the ReadyNAS units isn't the best idea either.
