kelgeo
Jun 30, 2012Aspirant
duo v2 not taking hard drives
Just purchased a duo v2. Hard drive wd 20 ears X 2 .ok getting corrupt root , tired factory default reset and os reinstall, did not work, that even gave on one drive a bad disk in raidar. So I again p...
HERBIEO
Take out the disk that raidar reports as bad and try with the 1 disk to start with see if you have any luck, if you do then update to latest firmware, and are you pressing the power button twice you need to for it to power down.
Edit it would be a good idea to download WD diagnostic tool and test the drive that reports bad.
