kelgeo
Jun 30, 2012Aspirant
duo v2 not taking hard drives
Just purchased a duo v2. Hard drive wd 20 ears X 2 .ok getting corrupt root , tired factory default reset and os reinstall, did not work, that even gave on one drive a bad disk in raidar. So I again p...
kelgeo
used windows disk management to delete the partition. I tried just the one drive, will not work. I doubt the other drive isn't good but I will check, it loads in windows if I reformat and it held information without a problem, no smart errors. Can I update firmware with a usb drive ??
