kelgeo
Jun 30, 2012Aspirant
duo v2 not taking hard drives
Just purchased a duo v2. Hard drive wd 20 ears X 2 .ok getting corrupt root , tired factory default reset and os reinstall, did not work, that even gave on one drive a bad disk in raidar. So I again p...
Jul 04, 2012Guru - Experienced User
All you needed to do is delete all the partitions. No need to merge anything.
However, the small amount not in the merged partition shouldn't have mattered either. You aren't deleting the data, just the partition structures themselves. Then the disk looks unformatted.
