willy134uk
Apr 20, 2012Aspirant
duo v2 settings help
hi ive just install my readynas duo v2 probly a silly question but i cant find the settings for the ftp or any settings for that matter ive noticed on the site how to pics the frontview is differant t...
mdgm-ntgr
Apr 22, 2012NETGEAR Employee Retired
Not referring to the firmware but the add-on mentioned under Limitations in the Release Notes I linked to. The add-on will enable FTP for use by ReadyNAS Remote. To install it click Configure on the Dashboard, go to Add-ons, click the + button on the far right, browse for where you've downloaded the add-on to etc.
If you open the Dashboard, click Configure, and go to Health > Logs and select Download Logs a zip file will be downloaded. Extract the zip contents and look at disk_usage.log. Can you post the contents of disk_usage.log here?
