willy134uk
Apr 20, 2012Aspirant
duo v2 settings help
hi ive just install my readynas duo v2 probly a silly question but i cant find the settings for the ftp or any settings for that matter ive noticed on the site how to pics the frontview is differant t...
willy134uk
Apr 22, 2012Aspirant
yes mate
Filesystem Size Used Avail Use% Mounted on
/dev/md0 4.0G 2.7G 1.2G 69% /
tmpfs 16K 0 16K 0% /USB
wheres all my space lol says ive only got 4.0g
heres my partition log
***** Disk partition log for channel 1 [sda] *****
Disk /dev/sda: 976773168 sectors, 465.8 GiB
Logical sector size: 512 bytes
Disk identifier (GUID): B9EFB3D5-0EE4-428B-B5F7-1714750540D9
Partition table holds up to 128 entries
First usable sector is 34, last usable sector is 976773134
Partitions will be aligned on 64-sector boundaries
Total free space is 4092 sectors (2.0 MiB)
Number Start (sector) End (sector) Size Code Name
1 64 8388671 4.0 GiB FD00
2 8388672 9437247 512.0 MiB FD00
3 9437248 976769072 461.3 GiB FD00
# partition table of /dev/sda
unit: sectors
/dev/sda1 : start= 1, size=976773167, Id=ee
/dev/sda2 : start= 0, size= 0, Id= 0
/dev/sda3 : start= 0, size= 0, Id= 0
/dev/sda4 : start= 0, size= 0, Id= 0
***** Disk partition log for channel 2 [sdb] *****
Disk /dev/sdb: 1465149168 sectors, 698.6 GiB
Disk identifier (GUID): C5B07CAC-71EE-4893-89CA-8384EB7F0EBA
First usable sector is 34, last usable sector is 1465149134
Total free space is 488380092 sectors (232.9 GiB)
# partition table of /dev/sdb
unit: sectors
/dev/sdb1 : start= 1, size=1465149167, Id=ee
/dev/sdb2 : start= 0, size= 0, Id= 0
/dev/sdb3 : start= 0, size= 0, Id= 0
/dev/sdb4 : start= 0, size= 0, Id= 0
unit: sectors
unit: sectors
