willy134uk
Apr 20, 2012Aspirant
duo v2 settings help
hi ive just install my readynas duo v2 probly a silly question but i cant find the settings for the ftp or any settings for that matter ive noticed on the site how to pics the frontview is differant t...
mdgm-ntgr
Apr 22, 2012NETGEAR Employee Retired
/dev/md0 is the OS partition which is 4GB and stored on the 4GB partition on the disks. You should also see your data volume(s) e.g. /dev/c/c mentioned in disk_usage.log
