willy134uk
Apr 20, 2012Aspirant
duo v2 settings help
hi ive just install my readynas duo v2 probly a silly question but i cant find the settings for the ftp or any settings for that matter ive noticed on the site how to pics the frontview is differant t...
mdgm-ntgr
Apr 22, 2012NETGEAR Employee Retired
Is it just a problem with the add-on? If so you might be better to contact the add-on developer (when you purchased the add-on you should have got an email with an email address you can contact if you have problems).
