DrJones
Jun 23, 2013Aspirant
Duo won't boot, how to proceed?
Hi. I've been getting error emails for some time that disk 1 in my duo was getting increasing SMART errors. Now it will not fully boot; the power light is steadily blinking, the green disk light fo...
Jun 23, 2013Guru - Experienced User
Normally the blinking LED is the one that was removed, is failing, or is resyncing.
Maybe try restarting again, but bypassing the file system check?
The ultra should be able to read the USB drives. If they are connected, maybe try removing them when you power down the system to try booting w/o the file system check.
