DrJones
Jun 23, 2013Aspirant
Duo won't boot, how to proceed?
Hi. I've been getting error emails for some time that disk 1 in my duo was getting increasing SMART errors. Now it will not fully boot; the power light is steadily blinking, the green disk light fo...
vandermerwe
Jun 23, 2013Master
The smart error, did you see what they were - reallocated sectors?
So much easier to sort out as you have a backup. If the edit: restart without fs check doesn't help, you should check the disks with vendor tools after powering off. If disk 1 is indeed the problem then just replace it. If both disks are gone, well just start again.
