DrJones
Jun 23, 2013Aspirant
Duo won't boot, how to proceed?
Hi. I've been getting error emails for some time that disk 1 in my duo was getting increasing SMART errors. Now it will not fully boot; the power light is steadily blinking, the green disk light fo...
Jun 23, 2013Guru - Experienced User
Are you using the instructions on page 15 here: http://www.readynas.com/download/docume ... 6Dec11.pdf
If it does come up, you can try replacing disk 1 with the NAS running.
Personally I replace disks much more aggressively than you do - esp. in a NAS, where accessing a reallocated sector means a drop in performance due to the increased seek time. I suggest pulling drives from a RAID array if they have > 50 reallocated sectors in the future, and redeploying them in less critical applications.
