glem
May 22, 2013Aspirant
Easy fix fan/temp OS6 issues on x86 legacy #no support
>> EDIT - 2014-04-12 << Before to hack your system, update first to 6.1.7. Built-in fancontrol support is there! 6.1.7 has been released: http://www.readynas.com/forum/viewtopic.php?f=1&t=76000 ...
scottminor
Jun 25, 2013Aspirant
It seems to be working. It shut down due to a high temp alert. I don't think the chassis fan is responding. Look at temp1.
coretemp-isa-0000
Adapter: ISA adapter
Core 0: +37.0°C (high = +76.0°C, crit = +100.0°C)
Core 1: +35.0°C (high = +76.0°C, crit = +100.0°C)
w83627dhg-isa-0a10
Vcore: +1.18 V (min = +0.00 V, max = +1.74 V)
in1: +20.93 V (min = +15.26 V, max = +12.67 V) ALARM
AVCC: +3.23 V (min = +2.98 V, max = +3.63 V)
+3.3V: +3.23 V (min = +2.98 V, max = +3.63 V)
in4: +6.06 V (min = +2.01 V, max = +3.07 V) ALARM
in5: +1.55 V (min = +2.48 V, max = +2.40 V) ALARM
in6: +1.55 V (min = +2.48 V, max = +2.40 V) ALARM
3VSB: +3.23 V (min = +2.98 V, max = +3.63 V)
Vbat: +3.18 V (min = +2.70 V, max = +3.63 V)
fan1: 856 RPM (min = 1214 RPM, div = 8) ALARM
fan2: 1467 RPM (min = 4821 RPM, div = 8) ALARM
fan3: 0 RPM (min = 1171 RPM, div = 128) ALARM
fan4: 0 RPM (min = 10546 RPM, div = 128) ALARM
fan5: 0 RPM (min = 878 RPM, div = 128) ALARM
temp1: +50.0°C (high = -3.0°C, hyst = +127.0°C) sensor = thermistor
temp2: +37.5°C (high = +80.0°C, hyst = +123.0°C) sensor = CPU diode
temp3: +1.5°C (high = +80.0°C, hyst = +123.0°C) sensor = thermistor
cpu0_vid: +0.000 V
