glem
May 22, 2013Aspirant
Easy fix fan/temp OS6 issues on x86 legacy #no support
>> EDIT - 2014-04-12 << Before to hack your system, update first to 6.1.7. Built-in fancontrol support is there! 6.1.7 has been released: http://www.readynas.com/forum/viewtopic.php?f=1&t=76000 ...
glem
Nov 28, 2013Aspirant
Did you install 6.0.x or 6.1.x ? if you have 6.0.x, update first to 6.1.x and check reports.
If all fans and temps seem to be working fine, you have just to add a sensors.d config file to compute the real values in fan and temp input expected by frontview.
Use this example working on ultra6 model to define your own config file. http://www.readynas.com/forum/viewtopic.php?f=51&t=71155&start=60#p411650
- chip statement is the name of your chip
- compute statement : example: compute fan1 0+fan3_input,0-fan3_input
The first argument (fan1) is the feature name. The second specifies how the raw value must be translated to the real-world value (0+fan3_input); The third specifies how the real-world value should be translated back to the raw value (0-fan3_input)
Find in the folder /sys/devices/platform/it8.... or w... or i8... (depend of your chipset) the files temp(x)_input and fan(x)_input which report your box values and use compute statements to put these values in the files expected by OS6 (files are not modified, changes affect only memory).
