tuxEvangelist's avatar
Dec 06, 2021
EnableSSH - Locked out from SSH
Dear All, I've installed EnableSSH on my Duo v2 successfully and was able to use it with the root account. While trying to enable ssh access to other users, I unfortunately locked root out before ma...
  • StephenB's avatar
    Dec 06, 2021
    tuxEvangelist wrote:
    Thanks for the quick reply, I managed to get into tech support mode and telnet to the Duo v2, but unfortunately the files of the ssh configuration are not present in this state. Is there a chance that I can mount other parts of the filesystem that contain the config files of the plugins that are installed?
    Yes, you need to mount the real OS partition.
    I've never owned a v2. but I believe these commands will work/
    # start_raid.sh
    # mount /dev/md0 /sysroot
    Not sure if you'll also need to chroot to get the commmands you need, but if you do try these commands:
    # mount --bind /proc /sysroot/proc
    # mount --bind /dev /sysroot/dev
    # mount --bind /dev/pts /sysroot/dev/pts
    # mount --bind /sys /sysroot/sys
    # chroot /sysroot /bin/bash
ProSupport for Business
