Digital999
Jan 07, 2020Luminary
Enabling bit-rot
For reasons buried in the long forgotten past we have NAS units without bit-rot protection on almost every share/file. Most systems are using Raid1enabled. If I understand this circumstance prop...
- Jun 07, 2020
The short answer to my original question is that for bit-rot protection to be enabled it must be set on the file/share and then all data after that point that is moved/used/copied will have the associated protection. Stuff that just sits there is not protected.
I set up a temp share and copied major parts of my data to the temp share. Subsequently I copied back to the same location that had bit-rot protection enabled. Took some time but certainly not impossible.
a_carneiro
Jun 07, 2020Tutor
No answer for you, sorry, but stumbled across this post and quite interested to know the answer as well....
- Digital999Jun 07, 2020Luminary
