bozolino1
Mar 29, 2011Aspirant
Enabling https for Subsonic?
the offical subsonic "getting started" page at http://www.subsonic.org/pages/getting-started.jsp gives these instructions: 4 Using https For improved security you can turn on https encryptio...
Thoto
Jun 18, 2013Tutor
Great news, friends !
I found how to make it work using the latest release...
you have to edit subsonic.sh, adding the SUBSONIC_HTTPS_PORT=4043 thing, as we had to do...
BUT... the way arguments are passed seems to have changed, and the bottom of the script lacks a line for sending the https port.
so, you must add
-Dsubsonic.httpsPort=${SUBSONIC_HTTPS_PORT} \
near the other arguments lines... And then, it looks like:
/c/webroot/subsonic/jre1.6.0_20/bin/java -Xmx${SUBSONIC_MAX_MEMORY}m \
-Dsubsonic.home=${SUBSONIC_HOME} \
-Dsubsonic.host=${SUBSONIC_HOST} \
-Dsubsonic.port=${SUBSONIC_PORT} \
-Dsubsonic.contextPath=${SUBSONIC_CONTEXT_PATH} \
-Dsubsonic.defaultMusicFolder=${SUBSONIC_DEFAULT_MUSIC_FOLDER} \
-Dsubsonic.defaultPodcastFolder=${SUBSONIC_DEFAULT_PODCAST_FOLDER} \
-Dsubsonic.defaultPlaylistFolder=${SUBSONIC_DEFAULT_PLAYLIST_FOLDER} \
-jar /c/webroot/subsonic/subsonic-booter-jar-with-dependencies.jar > ${LOG} 2>&1 &
Don't forget to stop.sh and start.sh and... tadaaaa ! it works using HTTPS !
so, you must add
