MichaelCH619
Oct 16, 2012Aspirant
Enabling Jumbo Frames on NV+ V2
I cannot figure out how to enable Jumbo Frames on my NV+ V2. The faq says that it will help performance http://www.readynas.com/kb/products/nvplus_v2. Any help would be appreciated. My hope is th...
Oct 18, 2012Guru - Experienced User
Even if the full path supports jumbo frames, you might still see slower speeds - so you should compare throughput before and after.
janforman wrote: Yes it's normal. MTU is 9000 after (can be verified by ifconfig)
Every other networking card must be set to this value and switch must support it - if not you get slower speed than without it.
