WinfriedTessin's avatar
Aug 01, 2020
Encryption failed
Hello, I have a problem to encrypt RN 102. "System" "Volume" displays "X-Raid" in green colour and buttoms "new volume" and "format" are in grey colour and could not be pressed. By pressing buttom "...
  • StephenB's avatar
    Aug 02, 2020
    WinfriedTessin wrote:
    unfortunately it is not possible to switch from X-RAID to Flex-RAID. Bottom X-Raid only change the colour from green to grey.
    When the colour is grey, you are in Flex-RAID.  So it is possible.
    The next step is to destroy it (done with the volume settings wheel).
ProSupport for Business
