Euchrid
Aug 03, 2016Aspirant
Endless resync of 104 after drive replacement
I have a ReadyNAS 104, accessed via a Windows 7 machine and a Windows 10. Firmware is 6.5.1. I attempted to expand it with a third drive, however that came up with errors (sectors reallocated) so I re...
- Aug 11, 2016I've reformatted the drives and they're working fine now
mdgm-ntgr
Aug 04, 2016NETGEAR Employee Retired
The status log by itself doesn't tell me much whereas if the download of the logs zip file had worked that would have provided much more useful information.
So do you have an up to date backup of your data?
You may wish to contact support on this one.
- mdgm-ntgrAug 11, 2016NETGEAR Employee Retired
How have you got on?
Something else you may want to try is ReadyNASOS 6.5.2-T500 (Beta 2) (there is a fix in that which may be relevant).
