techman05
Apr 21, 2012Guide
energy performance on duo v1?
I was trying to run the number for the wattage used on my battery backup and was trying to see what the wattage of a readynas duo was. I did as an estimate that my pc's power supply is set to 110[volt...
techman05
Apr 22, 2012Guide
Well I tried for first test to just disconnect battery backup from the wall and expecting a "ups disconnected warning" and didn't . I had set it for 90% and it took about 10 minutes to get there and it didn't shut off even after it dropped 20 percent more than that. The control panel was actively showing the drop but did nothing.
Just for fyi raidAR too a long time to get updated results from the nas even though I kepted pressing rescan every few minutes.
I am on .9-t6 so for now I'm thinking I 'should I post there and see if any others try and get the same result' ?
there should be no other signal to the nas other than "I'm discharging" right?
