techman05
Apr 21, 2012Guide
energy performance on duo v1?
I was trying to run the number for the wattage used on my battery backup and was trying to see what the wattage of a readynas duo was. I did as an estimate that my pc's power supply is set to 110[volt...
WalterMurphy
Nov 17, 2013Aspirant
techman05 wrote: I didn't even notice there was more than one page and I've looked at those specs many times. All I know is that my backup has 425va and it say that's an even conversion to watts and the UPS didn't even get a chance to go off before it was off with whatever was being put out. i have it set to shut down at 90% and it still sucked it dry before the timer turned the nas on.
Is there a site for estimated votlage for other Netgear products. I keep thinking I'd like to experiment with using some inexpensive solar kit in case of emergency just like the UPS is soposed to help with (though UPS is the have time to turn off and not to use long term).
Hello friend have you experimented with the solar kit? Even I am thinking of similar set up for battery charging so please share your experience and help me.
